L98 new cam cracked timing cover
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
I picked up a 89 Iroc. Po said it had an oil leak from the timing cover. What I found is the end of the cam made a perfect circle in the inside of the timing cover and also cracked it. That is where the oil is coming from. Engine is a L98 with the following:
http://sdparts.com/details/gm-perfor...parts/24502586
http://sdparts.com/details/scoggin-d...er/sd8060ragp2
http://sdparts.com/details/scoggin-d...-center/sd3816
Any ideas? Cam seems good, not walking. Car is at a shop. I am having him put it back together and me and a friend will start removing the cam to see if it was nstalled right.
Re: L98 new cam cracked timing cover
Timing cover was most likely smashed in.
There's normally about .080" of clearance there, or a little more; being a roller cam, the cam can't move more than about .010" to .015"; so it's not an "engine" problem as such.
Not using a gasket (which the gasket is certainly not especially "necessary"), or using a thin one, would aggravate that.
Yup, could be that too; in that particular cam it's long enough to drive the water pump; maybe the PO forgot to shorten it.
Car: 87 GTA
Engine: Two cracked out gerbils
Transmission: 700r with a probuilt automatics kit
ditto well said.In my past experiences If the lower timing chain sprocket isnt fully installed properly it can walk the cam out just a little and wear the cam holder down a bit too.add a gasket sealer gasket or dented cover to this and it will rub for sure.
Car: check
Engine: check
Transmission: check
NBrehm
Aug 25, 2015 11:49 PM
