bad idle when connecting temp sensor
Old Aug 19, 2011 | 12:03 AM
jreyes916's Avatar
Car: 89 camaro
Engine: 5.7 from an 89 blazer
i just got an 89 camaro with a 5.7 from a 89 blazer and when i looked under the hood the connector was off from the temp sensor so i reconnected it and the car doesn't idle right after driving for a minute or so because when i stop at a light or or just stopped in drive the idle goes up and down slightly and then wants to die but when i take the connector off it idles at about 900 to 1000 and is finebut check engine lights comes on when disconnected and turns off when reconnected my question is what could it be?
Old Aug 19, 2011 | 04:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: bad idle when connecting temp sensor
when i take the connector off it idles at about 900 to 1000 and is fine but check engine lights comes on
what could it be?
Assuming you are talking about the CTS (coolant temp sensor ) for the computer at front of intake then when it is disconnected , the computer puts engine into a "limp home" mode (why you have hi idle ) and lights the SES because it is not seeing the temp reading.
If engine runs cr*p with it connected ,then most likely it is faulty and giving the wrong temp reading to the computer.
$14 replacement
Same CTS for TBI/TPI/ LT1
Old Aug 19, 2011 | 06:51 AM
Or, you have the 305 injectors sitting on top of the 350 engine; a guaranteed recipe for being WWWWWWAAAAAAYYYYYYY too lean at all times. Disconnecting the temp sensor will make the ECM fuel the motor as if it's -40° outside; basically as rich as it can possibly go; which is why it runs somewhat OK like that, but not when it's delivering the (much lesser) amount of fuel it's programmed to deliver when it's working right.
Old Aug 20, 2011 | 11:50 AM
jreyes916's Avatar
Car: 89 camaro
so how do i know if it is the wrong one and i changed the temp sensor but still the problem is there
Old Aug 20, 2011 | 02:38 PM
Pocket's Avatar
Car: 91 Trans Am
Did you change the injectors or TBI unit?
Old Aug 20, 2011 | 03:22 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I thought the tbi for a 5.0 is essentially the same as the 3.7 tbi.??
Old Aug 20, 2011 | 04:12 PM
jreyes916's Avatar
Car: 89 camaro
i have not changed the injectors i believe that tbi came out of the same blazer the 5.7 came out of
Old Aug 20, 2011 | 10:15 PM
jreyes916's Avatar
Car: 89 camaro
could it be the iac
Old Aug 20, 2011 | 11:21 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
you need to do some hunting around under the hood to verify the injectors and all the sensors and ECM chip are for the 350.
Old Aug 20, 2011 | 11:37 PM
jreyes916's Avatar
Car: 89 camaro
ive checked under the hood and almost all the connectors look newer and how do you know if the injectors belong to the 5.7 and when i got the car i found 2 other ecm in the trunk
eightsixseven
Dec 16, 2024 01:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
