'88 IROC-Z to Vette swapability
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
a little off this path but i wasnt sure where else to ask, I've been told the '88 L89 350TPI is supposedly only a headswap away from the engine that came from the factory in the same year corvette, with the only difference being the aluminum heads on the vette. I have the feeling thats not all that goes into it, Any insight?
Re: '88 IROC-Z to Vette swapability
Yes there is one other minor detail; the heads in question lack the exh crossover passage, so the EGR had to be plumbed externally instead of being internal to the intake base.
Also I seem to recall something being different about the trim piece that covers the distributor.
So yeah, HUGE differences there...
The biggest diff in the heads is the angle on the middle intake bolts, 72deg. not 90 but that's not a big issue. The vette fuel rails are different also, rear hookups instead of front and indeed external EGR feed from pass side header.
The vette trim piece is aluminum, the f body one plastic. the texture on the manifolds and runners seems to be different too, On the vettes I have have it's a much rougher texture.
Why would you want to swap manifolds? They are the same internal size
Exactly; performance (HP and torque) isn't materially different between the 2. Most of the differences are just trivial details.
Engine: 383ci SBC
sorry its taken me so long to get back to this, I had heard there was a good amount of performance to be gained using the vette heads and manifolds as apposed to the iron ones
. although if all the other specs line up maybe just running the corvette manifolds might let things breath a little easier. what year vettes would have the right mainifolds?
. although if all the other specs line up maybe just running the corvette manifolds might let things breath a little easier. what year vettes would have the right mainifolds? Joined: Apr 2005
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Alum head L98's have factory shorty headers which drop down in the center like the old "ramshorn" manifolds
but they are to suit the "D" port alum heads
Engine: 383ci SBC
but the short headers have to outflow the square manifolds that came on the irocs right?
Car: 82 Z28
Transmission: T400
Engine: 383ci SBC
Its starting to sound like more trouble than its worth to make the swap, even if i did both the heads and headers(assuming they fit) it doesnt sound like it would mate up with the iroc intake manifold runners and plenum. so say everything did by some slim chance work out is there a signifigant gain in HP or weight savings to make it all worth it?
Engine: 4++,350 & 305 CIs
The heads are worth it if you do some port work on them. I would just use a nice set of aftermarket headers 4 the Fbody. Dyno Dons..
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/post...272-post3.html
