Surges and dies Cold, runs great hot!
Car: 1987 IROC-Z
Engine: 5.7 TPI
Hey guys, it seems I'm having the exact opposite problem most other people are having. when I first start my car up it runs like hell, surges and stutters 500rpm or so off where it wants to run no matter what the rpm is at until it heats up to operating temp and then it runs smooth.
also if it's idling at a light or a stop sign sometimes it will die right out if you even feather the gas up to leave the light. Again this goes away once the motor hits 160* or more.
87 IROC 5.7 tpi
any suggestions?
87 IROC 5.7 tpi
any suggestions?
Car: 1987 IROC-Z
Engine: 5.7 TPI
Re: Surges and dies Cold, runs great hot!
All of the injectors test good on my multimeter. I get an intermittent code 32 for egr but it isn't on when the engine surges like that. Also I wouldn't think a bad egr could cause a 500 rpm variance either direction. It's almost like it has a real nasty cam in it but without any guts.
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
My car used to behave like this and even threw a code 44. It couldn't figure out where it wanted to idle at and ran like it was about to throw a rod off a cold start. It would hunt for idle and even stall sometimes.
Try replacing your MAF sensor. That worked wonders for me.
Car: 87 z28 stock
Engine: 305 tpi
before you replace the maf, unplug it and see if it makes a difference. i wouldn't think it would, im not sure if the ecm uses maf data during open loop operation. what your describing actually sounds like it might be an egr issue, valve, solenoid or vacuum. the egr should be closed at startup if im not mistaken, if its partially stuck open it can cause these issues.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
code 32 can come and go and wont cause any drivability issues , just an annoying light. I doubt it is an egr issue.
Car: 1987 IROC-Z
Engine: 5.7 TPI
The car won't stay running without the MAF plugged in, unless I keep it revved to 2000rpm or so
also there is a strong smell of gas in that air housing where it connects to the throttle body.
Do you guys think it could be the ecm messing with the timing?
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I would replace the coolant temp sensor if it were me. That little sensor controls open and closed loop.
Car: 1987 IROC-Z
Engine: 5.7 TPI
I think I'm going to yank the motor out this labor day and just try to rebuild the thing, after 24 years I bet it could use it. Do you guys think this would be the right kit for my car, http://www.summitracing.com/parts/FEM-CSMHP761-000/ ?
db057
Aug 11, 2015 10:11 PM
