Terrible whinning noise.
Old Aug 22, 2011 | 10:59 AM
Jordan87TA's Avatar
Just a couple of days ago I replaced my ECM, ever since I have done that my car has been making a terrible high pitch squeal while on the throttle, but when I hit the brake, even if its just a little bit. The noise will stop completely, with this I dont think its a belt issue. The car can also not run for very long I'd say about 30 minutes before it begins to DRASTICALLY lose throttle response and stall out. I am wondering if this has to do with a vacuum leak I may have some where? Also when I replaced my ECM it was evident that burning was taking place around the rotor.
Old Aug 22, 2011 | 01:05 PM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
Re: Terrible whinning noise.
did you replace the ECM (engine control module / main computer) or the ICM (ignition control module)?
Old Aug 22, 2011 | 05:56 PM
Jordan87TA's Avatar
Oh my mistake, it was the ICM.
Old Aug 23, 2011 | 10:13 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
i think the issue is with your brakes since it stops completely when you depress the brake pedal even slightly. loose pad rubbing the rotor?
InfernalVortex
Apr 20, 2021 11:31 AM
BrianI
Oct 3, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
Randomtask2
Sep 7, 2015 05:06 PM
