fuel leak
Old Aug 24, 2011 | 03:55 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
fuel leak
I figured out the fuel leak finally. I need a fuel relief valve part number 10033125 and guess what not available from the dealer or part stores WTF. Does any one know of an alternative part that will work?
Old Aug 24, 2011 | 05:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: fuel leak
No, but I have a used one that works well. If interested, PM or email me your email address for pics or other info
Old Aug 24, 2011 | 07:23 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: fuel leak
what years are compatible
Old Aug 24, 2011 | 08:39 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: fuel leak
Pretty sure all third gens use the same part. Google the part # and you get a picture of the part and I've seen the same part on 83,84,87,90,91,and 92 cars.
Old Aug 24, 2011 | 09:05 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: fuel leak
ok I am going to PicknPull this weekend to get as many as I can find
Old Aug 24, 2011 | 09:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: fuel leak
Is that the fuel pressure regulator? These have a pretty thin cover and warp at the screws sometimes. I put a new diaphragm on mine and it still leaked. Straightened it out and put some washers under the screw heads and fixed it up.
Old Aug 24, 2011 | 09:29 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: fuel leak
Well, good luck. You'll be surprised how many of them don't work. Let us know how it works out
Old Aug 24, 2011 | 09:54 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: fuel leak
No this is a vent right off the tank in the back. It relieves the pressure in the tank
Old Aug 24, 2011 | 10:00 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Re: fuel leak
It really is hard to believe that the dealer was not reqired to keep making these considering how dangerous the leak is when one of these fail to work right. I wonder if there is anyway to force them to make them again.
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
