Ignition problem.
Old Aug 26, 2011 | 11:22 AM
Mikerace15's Avatar
Car: 1988 Red IROC-Z
Engine: 305 TPI V8
Transmission: Borg Warner T5
Ignition problem.
Did basic tune up on 88 Iroc. 305 TPI 5 spd, After I was done it ran terrible missing like hell at idle and missing the whole way up the revs and back fires though intake. First thought was plug wires are wrong. I checked them over and over and they are correct. I even had my brother check them and he ended up with the same result. I do recall the rotor being stuck and when i was prying it off i did hit the green round thing right under it (I know its for the timing but don't know the technical name.) and would assume this would cause all this? I even went as far as checking the timing with the electronic advance unplugged. At idle it reads 6 degrees like it should and when i rev it it reads 10~12 degrees. Any help is appreciated.
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
