Anyone ever used 194/160 305 heads on stock 305 bore
Old Aug 27, 2011 | 02:37 PM
Rob85TA's Avatar
If anyone can tell me if 305 heads fitted with 194/160 valves will fit stock bore please help.
Old Aug 27, 2011 | 03:35 PM
Vader's Avatar
Re: Anyone ever used 194/160 305 heads on stock 305 bore
They had better be very well located, with almost zero core and machining shift. Do the math - 1.94 + 1.60 + 0.020 for each perimeter (if you can even get the valves that close together in the stock center distance of the valve stems) barely fits in a 305 bore.
Even if they fit and everything clears, you're likely to encounter some shrouding complications. Unless you need to use those heads in your application you might want to investigate other options. Some older Ford and Pontiac valves are close to the correct stem length and offer different head diameters, like 1.90 and 1.58, etc.
Old Aug 27, 2011 | 06:13 PM
Rob85TA's Avatar
Thank you for the advise. I passed on the heads and im looking elsewhere.
Old Aug 27, 2011 | 06:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
just do a 1.94 / 1.50 combo. Fits much better
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
