Deciding on a cam
Old Aug 28, 2011 | 12:37 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Deciding on a cam
Trying to decide on a cam and lifter package for my 83 z28. Sbc stock internals, stock heads. Edelbrock Performer intake and matching 600 carb. Complete mallory ignition. I'm looking at cam and lifter packages but I wanted to know what you guys recommend. I'm looking for a good street cam that will wake my 83 up quite a bit. I was looking at one of the Thumpr cam and lifter packs on Summit racing. I don't remember the exact specs but it was listed to be a good street cam. I'm looking for a cam where I dont have to upgrade my converter. Along with the cam I also plan on doing a gear drive. What cam do you guys think I should go with?
Thanks, Chris
Old Aug 29, 2011 | 06:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At the risk of being overly blunt, Thumpr cams and gear drives are for wannabes.
Keep it simple. Comp XE256 is a good step up from the stock cam, but allows you to keep the stock stall converter. Since the stock valve springs are marginal and the gear drive is unnecessary, consider this full kit instead. http://www.summitracing.com/parts/CCA-K12-234-2/
Old Aug 29, 2011 | 07:19 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: Deciding on a cam
Just remember that everything works together, so a cam alone isn't going to give you an insane power increase. It will be more optimized than a stock cam (in most cases, some not depending on what it is). If you're wanting to "wake up" your ride, maybe invest in a set of gears as well? It won't give you a power increase, but you'll feel a difference.
If I were you, I'd also look at Lunati's lineup. I really like their shelf cams.
Old Aug 29, 2011 | 08:58 PM
Guest
Guest
Posts: n/a
I second this.
Old Aug 30, 2011 | 08:27 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
I "third" it!
Old Aug 30, 2011 | 11:15 AM
ChrisC's Avatar
Well I guess that I have to "fourth it". That cam seems like it would be a great upgrade while retaining the stock stall. The only reason I was thinking gear drive is because it is free. Theres a few gear drive sets lying around at my go to garage and the guys a friend of mine so it would be mine for the taking. That cam also comes in a kit with just the cam and lifters so if the drive stays free when I go to buy my cam, I might just jump on the cam and lifter kit.
Has anyone used this cam;positive and negative feedback would be helpful.
Thanks everyone,
Chris
Old Aug 30, 2011 | 11:42 AM
86LG4Bird's Avatar
I've not used that particular cam, but you would definitely not want anything more aggressive if staying with the stock TC. Plus, it complements the limited flow of your stock heads pretty well. I'd stick with a new stock timing set rather than the gear drive....cheaper in the long run and less aggravation.
Old Aug 30, 2011 | 02:17 PM
Guest
Guest
Posts: n/a
The cheap timing chains all stretch, so eventually the cam is quite a bit retarded, despite being ground 4 degrees advanced. With the gear drive, the cam timing should never change.
I had a Manley chain that didn't really stretch, but these days that set is near $100.
camaro71633
Sep 1, 2015 10:24 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
neekolzun
Aug 24, 2015 04:59 PM
BurlyChev
Aug 16, 2015 09:08 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
