Places to buy a custom rotating assembly?
Old Aug 30, 2011 | 01:25 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I'm putting a turbo on my 350 sb and am looking to go with a new rotating assembly, swapping out the cast crank/rods/cast pistons with a forged setup. My engine is a GM 350 HO crate engine with 25k on it. It is standard bore 4.000. I'm thinking I won't need to bore it .030 except possibly for the sake of piston availability. Compression ratio is currently 9.1 but I want to get it down in the mid to high 8's. Finding an off the shelf rotating assembly does not look like it's gonna happen, since I want to stick with standard bore, low compression forged pistons and have a one piece rear seal block. Might even go 383, not much more $. Any good places to check out? Advice?
Old Aug 30, 2011 | 01:41 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Places to buy a custom rotating assembly?
CNC motor sports AWESOME deals.... just do not let any mistakes happen while ordering. the return fees are INSANE
what 8's even my current vette 383 highend 12:1 build will push around 600HP
will not hit 8's
Old Aug 30, 2011 | 03:10 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I had mine from them too, chose all the parts and they ballance it http://www.cnc-motorsports.com/
Old Aug 31, 2011 | 09:01 PM
Car: '88 Iroc
Ok thanks guys, I will look into them more.
will not hit 8's
I'm talking compression ratio, like 8.5-9:1
Street Lethal
Apr 30, 2019 12:14 PM
Fast355
Dec 2, 2016 06:33 PM
mhatfield 14
Oct 24, 2015 07:48 AM
gixxer92
Sep 1, 2015 04:32 PM
