83 a.i.r. valve to 87 a.i.r. valve
Old Sep 1, 2011 | 12:21 PM
Mpperry001's Avatar
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
I need help with this question and ive searched the forums and come up with nothing. I am currently doing the serpentine conversion on my 83 trans am. The a.i.r. valve from the 83 has two wires plugged into it. The 87 A.i.r. valve had no plugs and seems to be alot simpler to install. Can i use the 87 valve to make my wiring simpler? or will this change somehow mess with the computer?
Old Sep 9, 2011 | 12:07 PM
Mpperry001's Avatar
Engine: Carb 305
Re: 83 a.i.r. valve to 87 a.i.r. valve
I still need help. Does anyone have an answer?? I cant find the info anywhere.
Old Sep 9, 2011 | 01:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I did the serpentine swap on mine. The difference I noticed were the electrical connectors were different, so I had to swap those. Also, the new one has no vacuum lines going to it where as the older one did.
Old Sep 9, 2011 | 02:23 PM
Mpperry001's Avatar
Engine: Carb 305
Thanks for the info. So did you adapt the new 87 valve to work? Or did you use the old valve?
Old Sep 9, 2011 | 03:00 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I used the new one. The old one doesn't fit with the serpentine brackets.
Old Sep 9, 2011 | 06:18 PM
Mpperry001's Avatar
Engine: Carb 305
ok thank you i will give it a shot
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
