all around starting problem
Old Mar 26, 2007 | 04:10 PM
texanwitharake's Avatar
Car: 1988 camaro
Engine: 2.8 tpi soon 383
Transmission: 5 speed manual
ok so im having some problems starting up my 88 camaro rs 2.8
ok when i try and start the car it sounds like it is about ot turn over but it dosent seem to go all the way almost liek ti is out of gas. im not sure what else to try u gus have any ideas?
Old Mar 26, 2007 | 05:21 PM
quadrojunk's Avatar
Re: all around starting problem
I dont know what you have checked, a list might help. The first thing I think of is the plate under the carb.
Old Mar 26, 2007 | 07:02 PM
Car: 1988 camaro
starter is brand new
gas lines under went some mateness
spark plugs been replaced
plenty of gas
700 cranking amp battery and cables hooked up to my truck
fuel pump seems fine
from what i can tell its either a spark problem or a fuel problem
any ideas?
Old Mar 26, 2007 | 08:44 PM
j dezzy's Avatar
Car: 87 TA
So the pump is definatly priming? And have you checked the fuel filter?
Old Mar 27, 2007 | 03:26 PM
Car: 1988 camaro
the fuel pump is deff priming i actuly had a gas line blow out during start so i had to replace the lines so i know its deff priming and i havent been able to check the inline filter the in take is fine
Old Mar 27, 2007 | 05:42 PM
j dezzy's Avatar
Car: 87 TA
Is it constantly cranking and just not starting? Or is it only cranking a few times and stopping...
Old Mar 27, 2007 | 07:10 PM
Car: 1988 camaro
its constantly cranking and no starting
Old Mar 27, 2007 | 07:11 PM
j dezzy's Avatar
Car: 87 TA
Try checking the ignition coil. you might not be getting spark.
Old Sep 7, 2011 | 12:35 AM
glevario's Avatar
Car: 88 RS
Engine: 2.8 MPI
Axle/Gears: n/a
I have the same problem I changed out the igition coil ICM. and starter but I still get no spark on my 88 RS 2.8. any ideas?
Old Sep 7, 2011 | 10:44 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Verify you are having spark, if you find out you don't have spark work your way back until you find out why. Throwing parts at problems gets expensive and time consuming.
Old Sep 7, 2011 | 11:47 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
start a new thread in the V6 section
Old Sep 9, 2011 | 06:56 PM
89RsPower!'s Avatar
Yes, diag until you find the problem instead of throwing parts on and crossing your fingers.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
