'90 IROC 305 TPI Tach not working correctly!
Old Sep 5, 2011 | 02:43 PM
BASSr's Avatar
Car: '90 IROC Convertible
Engine: 305 TPI LB9
Axle/Gears: 3.23 Disc Brake LSD
I recently picked up this '90 IROC Convertible with the 305 TPI, all stock.
When I got it, the tach was not working correctly. I start the car and the tach goes to zero then all the way over 7k RPM.
I checked all the wiring and all seems fine.
Any ideas on where to go from here?
Old Sep 5, 2011 | 07:28 PM
90IROCconv's Avatar
Car: 1990 Iroc-Z Convertible
Axle/Gears: 2.73 but not for long
Re: '90 IROC 305 TPI Tach not working correctly!
Seems to be an issue with these cars, look around on the site and you'll find a lot of tach problems. Mine doesn't peg at 7k, but its way off. about 800 rpm off at idle and almost 2000 rpm off at 3500!!!
Old Sep 7, 2011 | 02:56 AM
BASSr's Avatar
Engine: 305 TPI LB9
I looked around the site but nothing helpful that I found about trouble shooting.
Any one have a '90 wiring schematic?
Old Sep 7, 2011 | 10:56 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
https://www.thirdgen.org/forums/elec...meter-fix.html
Its a sticky in the electronics section if you're looking for it later
Old Sep 7, 2011 | 12:44 PM
coastiematt's Avatar
heard of the VSS going bad. dont' know for sure, but i'd read up on it.
(my 92 z28 convert is also erroneous tach rpms and speedo) I've been using my cell phone - speedometer application until i get it fixed.
good luck-
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
stalkier
Aug 7, 2015 04:49 AM
drathaar907
Aug 6, 2015 04:20 PM
