Is this oil pan worth it
Old Sep 8, 2011 | 09:36 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
I have a 383 engine in the shop. We are shooting for 500hp. I am trying to use all the best parts for this build. The guy building the motor is always telling me about different ways to grab a few extra HP's here and there, so I wanted to run this one by you guys.
Moroso 21017 oil pan
He says this oil pan is well worth the $450.00 it is going to cost me to get it up here. He says I will pick up a few extra HP's as well.
Have you guys used this pan or do you think it's worth the $$
I am just worried it will not fit on my 82 TA with headers.
http://www.jegs.com/i/Moroso/710/21017/10002/-1
Old Sep 8, 2011 | 10:08 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Is this oil pan worth it
A beat up old stock pan is just as effective, has better clearance, and costs a hell of a lot less.
Old Sep 8, 2011 | 12:14 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
I know the stock pan cost alot less. I was just wondering if the Partition Louvered Windage Tray and the 7 Quart Capacity is a great upgrade over a stock pan.
Old Sep 8, 2011 | 12:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It might be if you needed either of those things.
Old Sep 8, 2011 | 12:40 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I wouldnt bother with a fancy oil pan unless you were gonna drag or road race it constantly. High G's and oil moving away from the oil pump pickup and all that.
$450 I'd save and put towards something else. A roller cam setup or something.
It's a nice part and no one is gonna say "Man you wasted your money!", but it really depends on what other corners you're gonna have to cut to afford it. If it means pulling money away from a roller cam setup or some good rods or some good pistons, or good heads, then dont bother. If you're just looking for cherries to put on top, (or the bottom)and you have everything else covered and you just want to blow some more money... That's a different story.
Old Sep 8, 2011 | 12:46 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
Yes, this is what i am started to think. I don't think it would be worth the money on a street car. This is just what the guy building my motor was recommending. I really don't want to get into cutting my k member.
Anyone recommend a nice pan that will work without mods to the car?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
