Weird A/C, no air out of the vents question
Old Sep 13, 2011 | 02:02 AM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
So I got this 1985 trans am. It got 305tpi with auto transmission. Took the car for an engine rebuild (A/C worked great before that) so I came and got the car, checked the ac and it wasnt working, Ive tried to tell the shop owner that it was working before I dropped the car off but he was denying everything and telling me that they dont mess with the AC parts, so after 2 hours of them trying to fix it and arguing I got tired and took the car. So now when i turn the air I can hear the fan starting to spin and I can barely feel some air coming in from the vents. What can prevent the air to blow out of the vents?
Old Sep 13, 2011 | 05:43 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Weird A/C, no air out of the vents question
When you turn the fan on, does air blow out the top defrost vent, regardless of the position of the selector? If yes, most likely cause is that the vacuum hose from the engine to the A/C control was reconnected incorrectly.
Old Sep 13, 2011 | 11:26 AM
m16a2r's Avatar
Transmission: 700r?
Just checked and yes air comes out from defrost vents no matter the position of the selector, where is the A/C hose located?
Old Sep 13, 2011 | 12:03 PM
torque_is_good's Avatar
don't get confused.
it's a thin plastic vacuum line which comes out of the firewall and needs a vacuum source. it's probably tucked under something. Ever time I mess with my timing I end up disconnecting mine by accident, hop in the car, throw on the A/C and then slap myself on the forehead and go under the hood and reconnect it.
In other words, the source is near the distributor where it might need to be connected. it's probably supposed to be connected to a T adapter so look for a T which has nothing conencted to it.
Old Sep 13, 2011 | 01:23 PM
m16a2r's Avatar
Transmission: 700r?
thank you for the reply, gonna check it out today and update the thread.
Old Sep 14, 2011 | 02:00 PM
m16a2r's Avatar
Transmission: 700r?
Ive checked those vac connectors out and sure enough there were sitting very loose, easily pulled them out with no resistance, now gotta get some zip ties or something to tie them up nicely there. Thank you for the help. 1 problem down, 999 more to go, off to creating a new thread about my crazy idle problem.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
