Can Pontiac 2.5l Head Bolts be retorque?
Old Sep 19, 2011 | 06:25 PM
trevorsmith82's Avatar
Car: 82 Firebird/ 79 Camaro Berlinetta
Engine: 151 Pontiac Iron Duke TBI/ 305 SBC
Transmission: THM200/ THM200r4
Axle/Gears: 2.93/ 2.41
So for the past couple of days Ive been working on replacing my head gasket and when removing the head bolts it came to mind?
Any ideas anyone?
Old Sep 19, 2011 | 08:41 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Can Pontiac 2.5l Head Bolts be retorque?
head bolts are cheap if in dout replace them cheep insurance but Ive reused stock head bolts many times and never had a problem just put some moly lube on them before torquing them down.
Old Sep 19, 2011 | 09:19 PM
Thanks thats what I kinda figured.
Got any tips on removing the cylinder head though, its being a little stubborn to lift off the block
Old Sep 19, 2011 | 09:49 PM
HF_monster's Avatar
Transmission: th350
dead blow hammer works most of the time
Old Sep 20, 2011 | 08:41 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Those head bolts should without a doubt be replaced.The best deal is to buy a Fel Pro head gasket SET,it comes with all the gaskets you need,as well as the new bolts.
On a side note,2.5 heads are notorious for cracking,I strongly advise you to have it checked for cracks,and resurfaced.
Old Sep 23, 2011 | 02:17 AM
I order a new bolt set when i ordered a reman head off ebay
for the price i got quoted by a machine shop i went ahead with a reman head
thanks
jhawkeye
May 25, 2022 06:33 PM
evilstuie
Jan 9, 2020 08:29 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
355tpipickup
Aug 25, 2015 12:54 AM
