89 Iroc will NOT get into gear.... Please help
Old Sep 21, 2011 | 11:37 AM
leedavidalan's Avatar
Hey fellas I have an 89 Iroc, manual tranny. He just dropped in a 383, and installed a new centerforce clutch. Car fires up beautifully. But once its on I can't drive it because I can't get into any gear. I'll push in the clutch pedal, and the shifter won't enter anything!!
Any immediate thoughts? We changed the clutch fork and got the recommended throwout bearing for the clutch. Where else should I look?
Thanks guys.
Old Sep 21, 2011 | 04:16 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 89 Iroc will NOT get into gear.... Please help
are you able to put it in gear with the car not running? If so you need to start looking at the clutch and see whats going on. Why did you change the fork? Are you sure there is no air trapped in the hydrolic system? If you can get a helper have them sit in the car and push the pedal down while you watch to see how far the slave is pressing the clutch fork back. Assuming all the parts are correct I'd say it's def. in the hydrolic system, be it trapped air or a failing part.
Old Sep 21, 2011 | 10:23 PM
Yes with the car off I can shift easy. When its on, I can enter no gear. We changed the clutch fork because the stock one had a broken clip that holds firmly in place the throwout bearing. Between my brother and I we can confirm that the bearing is pressing against the plate. We've also bled the system to make sure there is no air trapped, but I suppose we could do it again rather extensively.
Not sure what else man. Maybe we'll just remove the whole tranny again and start from stratch. Thinking something in the hydrolic system as well. If anything else comes to mind please by all means let me know.
Thanks.
Old Sep 22, 2011 | 12:59 PM
89RsPower!'s Avatar
If you are able to put it in gear without it running easily , it's gotta be somewhere in the clutch. Either you have the wrong fork, bearing, air trapped in the hydrolic system, or a hydrolic component has failed. When you are under the car watching to see the slave push the fork back try to get a reasonably close measurement of how far the fork travels. Post measurement up here, that way we can figure out if it is a problem with the hydrolic system or a problem with the fork and/or throwout bearing.
Old Sep 23, 2011 | 09:42 AM
89RsPower!'s Avatar
Also just keep in mind just because the bearing is pushing against the plate doesn't mean its pushing it far enough to allow the clutch to release completely which would cause the issue you're describing.
Old Sep 23, 2011 | 01:59 PM
We're getting close to 3/4 of an inch of travel from the slave. That should be within spec correct??
Old Sep 23, 2011 | 02:15 PM
Agreed.
Does anyone know what the distance between the bearing and the pressure plate should be?? Meaning when the clutch is engaged should the bearing be resting on the "fingers" of the plate or should there be a slight gap between them??
Old Sep 23, 2011 | 06:15 PM
89RsPower!'s Avatar
Wish I could outside look but I no longer have the car I converted to manual. I used
http://www.summitracing.com/parts/RA...&prefilter=1go I was running an older 2 piece RMS block (010) so I used a flywheel from an old straight 6 2nd gen car. Everything went togather and worked fine. Did have some issues with air in the system where the clutch wouldn't fully release while shifting so I had to pull it out and bench blead it before reinstalling. After that all was fine. It's been a while for me but 3/4ths of an inch doesnt sound like it's traveling far enough, maybe someone can confirm one way or the other? You could also try and see if you could manually push the fork back farther with a small bar and see how much more travel there is beyond where the slave pushes it to.
Old Sep 23, 2011 | 10:10 PM
I could have sworn that GM called for a hair more than 1/2" of of travel. Based on that I assumed the 3/4" of travel im getting was well within spec. Hhhmmmm......
I'll see if I can wedge a pry bar tomorrow. I need to get this thing running already! lol
Old Sep 26, 2011 | 10:04 AM
Finally got the BEAST running. Turns out the flywheel had been cut one too many times and was missing a ton of "meat". Slapped a new flywheel on and all is good.
Old Sep 27, 2011 | 08:52 AM
89RsPower!'s Avatar
wow must have been 1 worn out flywheel, glad to hear you got it fixed
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
