Hot Alternator
Old Sep 21, 2011 | 04:05 PM
lethaldomestics's Avatar
Hot Alternator
My alternator is getting hot to the touch and the lead to the bat. is melting Any ideas?
Old Sep 21, 2011 | 07:41 PM
torque_is_good's Avatar
Re: Hot Alternator
my alternator gets hot to the touch too. Heck, everything metal which is under the hood gets hot to the touch. The cable going from the alternator to the positive connection block should be wrapped in the plastic ribbed sleeve
Old Sep 21, 2011 | 08:38 PM
Re: Hot Alternator
What's the batt voltage with the car not running?
What is it with it running?
Put the meter on AC volts. What's the reading at the alt output terminal?
Old Sep 21, 2011 | 11:06 PM
Re: Hot Alternator
Ok so when i mean hot to the touch really hot. seems unusual.
i will test bat componets tom. thank you very much
Old Sep 21, 2011 | 11:33 PM
86Stevo's Avatar
Re: Hot Alternator
test it and find out just and idea maybe its a high amp alternator and its putting out alot and melting your wire.
my gauge when my alt is charging its is around 14 ball park give or take .5
i can be completely wrong but just a thought they have tons of alternators for our motors with different out put specs
Old Sep 22, 2011 | 01:07 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Hot Alternator
im betting on a bad or failing ground wire
apie2546
Oct 16, 2016 02:24 PM
Thaney9
Oct 24, 2015 07:26 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
