Correct oil pressure???
Old Sep 26, 2011 | 12:32 PM
meso5012's Avatar
Car: '04 Ram Hemi & '86 Camaro
Engine: 327 bored to 355
Axle/Gears: 323 posi
What is the ideal oil pressure for a small block at idle? I got mine fired up this weekend and it was reading 40's psi at idle ...I couldn't run it long due to no coolant in the system yet... still getting my serpentine system worked out. Any ideas?
Old Sep 26, 2011 | 12:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Correct oil pressure???
10 psi per 1000 RPM or better
Old Sep 26, 2011 | 12:53 PM
meso5012's Avatar
"or better" Is 40psi too much? I realize once the engine is warm the pressure will fall some but I'm worried about cold starts causing leaks.
Old Sep 26, 2011 | 12:59 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Most new cars have 40-60psi
Old Sep 26, 2011 | 01:23 PM
meso5012's Avatar
I dont know that I would classify this car as new...but thanks for the input. I'll take that as a yes and 40psi is ok?
Old Sep 26, 2011 | 01:36 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
40 at idle is fine.
Old Sep 26, 2011 | 03:31 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
40 at cold idle is going to be a lot lower at warm idle, but I agree it's fine.
My well-broken in 30k mile 355 that gets driven with conviction gets 60+ psi cold idle, around 30 warm idle. 25-35 warm idle is average. 15 warm idle is adequate. Much below that is still technically good enough (see the 10 psi per 1k RPM rule) but it would bother me.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
