Missing a screw on piece on this nipple on the engine
I recently bought this car and noticed gasoline slowly oozing out of this piece. I don't know what it's called, but I believe it's missing a cap of some sort. If I knew what it was called, I would get the part I'm missing.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Missing a screw on piece on this nipple on the engine
You need a new Schrader valve. Fuel shouldn't be leaking from there, cap or not.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You might be able to tighten the schrader valve. There is a plastic cap, but it just keeps the dust out, not the fuel pressure in.
Engine: 4++,350 & 305 CIs
Try and snug up that valve before getting a new one. A tire shop will have the tool or you can buy one cheap from a parts store.
I have a crap load of those caps.
Early cars had aluminum and SD cars got the black plastic, from what I have seen.
I picked up most of my spares at a JunkYard from front drive V6 Jbody cars.
I'll try to tighten the valve a bit and see if that fixes the problem. I just noticed the spiraling grooves and immediately assumed something essential was missing. Thanks for your help, guys.
Engine: 383 Carb
Transmission: 4L60
It's not the outside part you'd need to try to tighten, it's the core inside.
1992 Trans Am
May 10, 2023 07:19 PM
