can someone tell me what this part is under hood?...for rear windshield wiper/washer?
Take a look at the picture, see the cylindrical item with a green wire plugged in at the top....what does this do for a living?
Has a hose attached to one port on side that goes into the firewall, other port has nothing just points straight down.
Almost looks like windshield washer pump, however thats attached to the motor on the firewall right?
Its an 86 IROC 5.0 TPI automatic
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: can someone tell me what this part is under hood?
I kind of want to say it has something to do with a clutch...but your car is auto, not really sure what it is though.
Engine: 4++,350 & 305 CIs
thats a wiper squirter pump. it should b on the jug or the wiper motor. depends on year of car..
maybe some one rigged up a drink maker.. we did that back in highschool(long time ago!). we could make mixed drinks going down the road.
we also used them to spray the road with VHT but it was all mounted in the trunk..
Engine: 3.8, 3.4
Weird, mine looks different than that, hard mounted to the firewall. Or at least from what I recall.
Looks exactly like one to me and my washers do not work currently. However, the arm is broken on the steering wheel too. I traced the hose from the jug and it goes to a motor thats attached to the wiper motor housing. One of the hoses has a check valve looking thing as a TEE with a line coming off it that just hangs below the pwr brake booster connected to nothing, figured it just drained/vented on the ground.
Im stumped as I dont know if its factory or aftermarket
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Ya very interesting def a washer fluid pump tho what year is that again?
Its an 86
heres the VIN 1G1FP87F6GL190791
I just bought this from a member here, he claimed everything was bone stock, everything worked runs great....needless to say it has alot of issues, washers and this thing is just one of the many Im trying to iron out.
I really appreciate everyones help
After looking at this car, it used to have a seperate rear windshield wiper (hatch has been changed but glass has scratches). I bet thats what its for.
Was there a seperate switch/washer for rear windshield wiper?
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: can someone tell me what this part is under hood?...for rear windshield wiper/was
ive never seena 3rd gen with a rear wiper.....
rear wiper indeed, my 83 z28-E has the same pump.
You can just see the top of it w/ connector w. green wire next to the MC
underside of rear hatch, motor stuffed under bulge
Car: 91 Camaro RS
wow, i never new they came with rear wipers, did they stop them early on or something?
Car: 87 iroc-z
Engine: 454
Transmission: th350
ive never noticed one either. a rare option?
Car: 91 Camaro RS
damn, makes me want a rear wiper...
it would be handy, however the previous owner of mine must have used the wiper with a bad blade and just let the metal screech across the glass....its all scratched up and needs replacing now.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
1983, 1985camaro, 1g1fp87f6gl190791, firebird, gen, glass, hatch, hood, part, pump, vin, washer, whats, windshield, z28
