Elect. Issue ?????
Old Oct 2, 2011 | 06:00 PM
joecool1979's Avatar
Car: 1989 Chevy Camaro
Engine: 2.8L V6
Transmission: 89 GMC Jimmy Part Camaro Part Jimmy
Axle/Gears: Duno at this time
Elect. Issue ?????
Ok this car has plagued me since i bought it in 08, Some of the guages work some dont, this car has been a haus paid 800 for it and drove it 35k before the trani gave out, it set up in 100+ weather in texas for the entire spring and summer Just got her up and going. Anyway keeps blowing the fuse for the Turn Signals, Ive often wondered about the wires that go to the battery, seems like alot also, I had to put in a toggle switch and push button because of the starting issue its had Im sure its a relay but im also on a real tight budget, scrap wire and testing is no problem but I need to figure out whats what at the battery and does the hot wire at the alternator, is it suppost to go directly to the battery? any help would be cool
OK ive narrowed it down to it blows the fuse when you put it in reverse? If that helps get an answer
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
