Will Pulling the A/C Get You More MPG's?
Old Oct 5, 2011 | 09:01 AM
Dmorrow's Avatar
Car: 1987 Iroc-z
Engine: 305 tpi
Axle/Gears: Posi
my a/c does not work and i plan on doing an LS1 swap sometime in the future. Is there any benefits of pulling the a/c?
Old Oct 5, 2011 | 09:35 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Will Pulling the A/C Get You More MPG's?
slightly better flow to the radiator.. not going to free up any HP or anything tho, the compressor is little more than an idler pulley unless the clutch is engaged (when the a/c system is on and working)
Old Oct 5, 2011 | 09:42 AM
Dmorrow's Avatar
Car: 1987 Iroc-z
Engine: 305 tpi
Axle/Gears: Posi
Ok, is that job time intensive?
Old Oct 5, 2011 | 09:48 AM
89RsPower!'s Avatar
not really if you know what you are doing, hardest part is swapping the heater box for a non-a/c box....
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Amillionoh7
Sep 11, 2015 11:36 AM
MSgt Luttrell
Sep 5, 2015 11:28 AM
85Special
Sep 3, 2015 04:21 PM
