Good harmonic balancer?
Old Oct 11, 2011 | 11:11 AM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
I'm putting a new engine in my car, going from a 305 to a 350. I want to go ahead and get a new harmonic balancer, even though mine may work on the 350 I'd rather get something better since the 350 I'm getting is a performance upgrade and will have a much higher peak RPM performance mark.
The problem is, I wasn't prepared for all the options available on this part lol. There are 193 results when specifying my engine size and all on summitracing haha.
I read somewhere else that the smaller and lighter the balancer the better. But I don't want to spend a ton of money on this part. I can get a straight stock oem replacement for 33 dollars. I'd be willing to spend maybe up to 75 on something better if it's worth it.
The smallest one I can find that is in that price range is this one:
http://www.summitracing.com/parts/SCA-D-80010/
Does anyone know if that is a good balancer to go with?
The cheapest SFI approved balancer I see is a summitracing brand part for 130 dollars, and it's got an 8 in diameter on it. That is a bit more than what I want to spend for this.
Thanks for any help!
Old Oct 11, 2011 | 11:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Good harmonic balancer?
Stock replacement should be fine for anything you're going to run on the street.
Old Oct 11, 2011 | 12:34 PM
Steven6282's Avatar
Stock probably would be fine, but I want something a little better. This is a performance upgraded engine that I'm getting Dyno'd at 383 hp. It's mostly going to be driven on the street, but I might take it to a track or an autocross for fun occasionally (nothing serious or expecting to win or anything).
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
