Cam suggestions for a TPI 350
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Whats a good cam for a TPI 350 without having to tune it?
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: Cam suggestions for a TPI 350
Only the stock cam. Everything else should be tuned.
Actually, you might want to even tune your stock cam
Only the stock?!?! Not even a really mild one?
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Axle/Gears: 3:42
keep duration below 220/220 @.50 and lift under 470/470 and you will be fine. You may lose some low end torque tho if you go that big anyway. I have heard good things about the crane 2032 cam 214/220 and 452/465 lift.
Axle/Gears: 3:42
you will probably be surprised if you tune it or get your chip tuned.
Yeah I might tune it down the line but i don't have the funds for that right now
Axle/Gears: 3:42
Axle/Gears: 3:42
that crane looks pricey tho
EDIT: Ignore this, I didn't see that you said 214/220 at .50 sorry
http://www.summitracing.com/parts/SUM-K1102/ and for cost purposes would something like this work instead? The engine is a base 350 crate same as this http://www.summitracing.com/parts/NAL-10067353/ and the cam specs stock are 383/401 lift 194/202 duration at .050 in. so its definitely a step up
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
The Crane Compucam 2032 or even 2031 seem to be a good choice.
From what I've rad, the TPI with MAF seems a pretty flexible and adaptable setup and you may not need to retune the EPROM.
But would the summit one work? I don't see any major difference that wouldn't make it work and my engine is a flat tappet not a roller.
Axle/Gears: 3:42
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
