Completely lost with 92 firebird formula-PLEASE Help
Old Oct 15, 2011 | 02:39 PM
Joshastine's Avatar
Car: 1992 Firebird Formula
Engine: 305 FI
Hey guys, stoked to be a part of this site.
I just got this car. Very clean. It's the formula edition, 5.0 FI auto with vats system.
The guy said it needed the second injector. Drove it around the block with injector two unplugged (the bad one supposably) and let it idle. After ten minutes of being on it shut off on it's own as if I turned the key off. There was no sputtering. I tried starting it and it would crank but not fire. Plugged in other injector and same deal. Started going through more injectors unplugging them and still nothing.
Did online research and similar problems on here. Went and bought an ignition module and coil. Once they were installed the car fired right up on all cylinders. Drove around and once again after ten minutes or so it shut off without warning while driving. Couldn't start the car for at least an hour and when it did, it would only start with injector two unplugged. When all injectors were plugged in it would only fire for a second or two with starting fluid.
The next day it started on all 8 injectors again. Let it run, wasn't shutting off. We noticed smoke and the catalytic converter was beat red - assuming it was clogged, we cut it off. Let it cool and once again wouldn't start not even with injector unplugged. Yesterday I noticed the MAP sensor was melted, thought "BINGO!". Bought a brand new one, drove around the block and let it run: didn't shut off. I turned it off waited a few seconds and it fired right up. I was ecstatic!
Came back out twenty minutes later after cutting exhaust to fit it l, went to fire it up and bring it into the garage and it once again cranked yet no fire. Unplugged injector two and it started. Not throwing any codes on the dash or anything.
My mind is blown and I don't know much about cars other than from trial and error so if I seem like an idiot, I am. But I'm trying to learn so if you could, help a fellow out!
By the way i was told it has new fuel pump & filter, wires & plugs and looks to have a new distributor cap.
Old Oct 15, 2011 | 05:01 PM
Joshastine's Avatar
Engine: 305 FI
Re: Completely lost with 92 firebird formula-PLEASE Help
Distributor pickup coil?
Old Oct 15, 2011 | 05:07 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
i smell a bad distributor
Old Oct 15, 2011 | 07:48 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
you need to test your injectors. test for ohms to find out which ones are bad. then always replace all 8 at the same time.
Old Oct 16, 2011 | 01:03 PM
Joshastine's Avatar
Engine: 305 FI
I'll do that today and update how it reads out. If they're fine I'll head towards distributor.
Thanks guys!
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
KO1
Aug 31, 2015 06:31 PM
djmarch
Aug 19, 2015 12:07 PM
