Fuel filter question:pulling fuse for fuel pump allowing engine to stall safe?
Old Oct 19, 2011 | 12:31 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hello all I got a 88 firebird L05 swap and getting ready to do my fuel filter and I was just wondering if it wouldnt mess anything up in the engine to pull the fuse from the fuse block for the fuel pump start the engine allowing it to stall and then do the fuel filter allowing for a easier change not getting fuel every where? I have heard of this but never thought of it.I usually just pop the gas cap off and get some rags. Just wondering thanks for the input.
Old Oct 19, 2011 | 12:15 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Fuel filter question:pulling fuse for fuel pump allowing engine to stall safe?
It's going to bleed off no more than normal pressure at the injectors since they will continue to run.
The schrader valve on the fuel rail will do the same thing. I'd hook my fuel gauge on there and do it that way.
Fuse would work though.
Old Oct 19, 2011 | 12:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you relieve pressure at the schrader valve, you have to do something with the fuel that vents. If you pull the fuse, you don't.
Old Oct 19, 2011 | 06:07 PM
Thank you Just wanted to Make sure it was fine before I pull the fuse
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
