MAF check engine light, but that cant be
Car: 1988 Trans Am GTA
Engine: L98, 305, 5.0L
Transmission: Stock
My check engine light comes about half the time, but not all the time. The code is a MAF, but i asked my mechanic who previously owned the car, and said that cant be because a new MAF was put on it less than 8 months ago. Im suspicious about the code because it only comes on sometimes. It effects my idle making it go about 500 and jumps up and down a little bit, but when i reverse out of my driveway when this happens, i really have to give it alot of gas, because the throttle seems to be less responsive when the light comes on. Any ideas of what this may be?
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: MAF check engine light, but that cant be
There are many post's in here about code 33, there can also be many reason's for a code 33, MAF sensor, MAF relays, intermitant wire fault, vacuum leaks, ECM. It can be a nightmare to find sometimes.
Car: `86 SS / `87 SS
Read more posts on here about that code; you'll figure it out.
If you need to know what signal the MAF is sending back to the ECM, get a scanner.
He's right that 8mo. and normal mileage shouldn't make for a bad MAF.
Keep a clean paper air filter installed and it should last you a while. I wouldn't run an oiled gauge (K&N type) filter on a MAF car.
