VATS resistance question
Old Oct 19, 2011 | 11:54 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
hello
I have a 90 5.7 with VATS. I am experiencing some issues with engine cut out. It feels like no fuel, is occasional/random. I have replaced so many other parts I figure I will look into VATS (the symptoms are there).
first question is
There are 15 different codes that GM uses in their V.A.T. systems. They are as follows, (1) 402, (2) 523, (3) 681, (4) 887, (5) 1130, (6) 1470, (7)1870, (8) 2370, (9) 3010, (10) 3740, (11) 4750, (12) 6040, (13) 7500, (14) 9530, (15) 11800
If my key is a code 7 and my actual resistance is 1851 instead of 1870 would this cause a failure or intermittent failure? Is there an allowable range for resistance built into the VATS program? Or does VATS expect exactly that resistance?
thx
Old Oct 20, 2011 | 06:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS resistance question
No
Is well within allowed range
See
https://www.thirdgen.org/vats_passkey_system
I am experiencing some issues with engine cut out. It feels like no fuel, is occasional /random.
When cranking car over?
Do you have a code showing for VATS failure?
Old Oct 20, 2011 | 10:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Does the ecu only check vats at start up or at any time when the engine is running? What if the key was loose and could be removed? Don't laugh. I've had that on an older car.
Old Oct 20, 2011 | 11:08 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
+ or - 10% on the resistor value.... If your lock assembly is that loose replace it.. that means anyone can take your car
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
