Oil pressure sensor/swtich
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
I have an 84 trans am with a 350 swap that someone did a poor job on with electronics. The oil pressure gauge in the car sits as high as it can go (past 60) continously except for 5 minutes where it seemed to work about a week ago. Where would the oil pressure sensor be on a 77 350 block? I know the oil filter is under the car right next to the pan, im guessing it would be around there? Also, do I need to change the entire setup or just the switch?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil pressure sensor/swtich
Stock location is the top of the block near the distributor.
Car: 1984 Trans Am
Axle/Gears: Stock
Is it either of these. The pictures I pull up for them doesnt look terribly similiar to either.
Car: 1984 Trans Am
Axle/Gears: Stock
Whats the silver thing on the side by the distributor? That is what i was snapping a pic of. Im guessing it would be on the drivers side?
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
That's the vacuum advance pod. What you want is on the rear of the motor on the driver's side.
A 350 sits no closer to the firewall than any other engine in a thirdgen.
Car: 1984 Trans Am
Axle/Gears: Stock
Im probably just use to my old torino engine bay still. I found the oil sensor but does this plug go to part of the wiring for it?
