What's this wire?
Old Oct 20, 2011 | 08:07 PM
tricky1's Avatar
Car: 1982 Pontiac Trans Am
Engine: Chevy 350 Vortec Roller
Transmission: Turbo 350
Axle/Gears: Moser 4.11
What's this wire?
I has a fire in the engine compartment of my 82 Trans Am and had a good bit of damage to some of the wiring but nothing I can fix. What concerns me is this red wire that looped out of the plug of the wiring harness that plugs into the firewall on the drivers side of the car. I think it's a fuable link. If so, what are my chances that I'm going to have damage to the harness inside the dash. He're a link to the pic.
http://imageshack.us/photo/my-images/705/dscn0248o.jpg/
Old Oct 20, 2011 | 08:20 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: What's this wire?
depends on how bad the fire was. the plug doesnt look damaged at all, so chances of the wires in the dash being burnt up are minimal. was it an electrical fire, or gas fire? as for what that wire is exactly, its hard to tell from the pic.
Old Oct 20, 2011 | 11:18 PM
tricky1's Avatar
It was a gas fire. Carb feed line.
Old Oct 21, 2011 | 03:15 AM
travis401's Avatar
Car: 91 Camaro RS
then yea, the dash wires shouldnt be burned at all if thats the extent of the damage in the bay.
Old Oct 22, 2011 | 11:57 PM
tricky1's Avatar
C'mon guys. I really need some help on what this wire is. I've been told it's a fusible link. If that's what it is I nedd to know how to replace it.
Old Oct 23, 2011 | 12:10 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The last F.L. I fixed was due to a previous-owner crimp-job on the car failing after over a decade of use.
I referenced the wiring diagrams in the Helms factory service manual. They're great books to own when you're doing your own work.
Usually on GM stuff, fusible links are more commonly at the starter wiring or nearer the battery, not at the driver's side firewall.
Good luck.
Old Oct 23, 2011 | 09:40 AM
travis401's Avatar
Car: 91 Camaro RS
yea, there isnt a fusable link near the bulk head connector. you dont really need to know what the wire does to fix it. just cut off the destroyed part and properly splice in new wire and youre done.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
