CAR WON'T START AFTER RUNNER, TB, & INJECTOR SWAP!
Old Oct 26, 2011 | 02:21 PM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
ok i work at 9 tomorrow so all help would be amazing, needing extra cash i sold my slp intake runners, bbk 52mm TB, and wanted stock fuel injectors. so i pulled it all off and replaced those 3 with stock parts. the used stock injectors are all in spec, the 2 sensors off the bbk tb were put back on the old tb so i know they good, used new bolts for the runners and new gaskets. i unplugged the ecm w battery still hooked up to remove my custom chip for the bigger injectors that were in there, so i thought i might have messed w vats doing so? i unhooked battery for an hour but it still wont start, i cnt see any unplugged wires or vacuum, please help! im so ducked right now!
-SHANE
Old Oct 26, 2011 | 02:38 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: CAR WON'T START AFTER RUNNER, TB, & INJECTOR SWAP!
DOes it crank?
Do you have spark?
Do you have fuel pressure?
Old Oct 26, 2011 | 08:08 PM
89shane350's Avatar
Originally Posted by Impaqt
DOes it crank?
Do you have spark?
yea it cranks
not sure, ill try to test that, of course its cold and raining, fml!
yes on pressure
Old Oct 26, 2011 | 11:14 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Did you properly adjust the TPS when you put it back on?
Did you reset the IAC when you put it back on?
Did you reset the minimum idle?
Good luck
Old Oct 27, 2011 | 12:00 PM
89shane350's Avatar
what about this... i pull custom chip that were for bigger injectors, so don't i need the stock prom or whatever it is so it runs now??? where do i find one quickly!?
Old Oct 27, 2011 | 01:03 PM
Impaqt's Avatar
Quickly?
Sinister might be able to burn you a factory EPROM and send it to ya...
http://www.gmtuners.com/
What happened to stock PROM?
Old Oct 27, 2011 | 01:18 PM
89shane350's Avatar
Quickly?
problem solved, i'm an idiot, i didn't know the stock prom/memcalc thing was attached to the moates ! ha runs good!
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
