IMPORTANT QUESTION about storing my car for the winter.
Old Oct 27, 2011 | 07:56 PM
ewskater92's Avatar
Car: 1986 IROC-Z28 Camaro
Engine: 350 carbureted (swap from 305 TPI)
Transmission: 700R4 rebuilt with shift kit
Not sure what category to put this in so I hope this is ok...
I'm am storing my car for the winter. I just need to know what i need to do to ensure it will be ok in the spring. Some things I was thinking were to start it once a month? Do I need to drain the gas or coolant...? I really have no idea, that's why I'm coming to you guys
thanks guys!
-Evan
Old Oct 27, 2011 | 11:07 PM
puddingmmmmmmmm's Avatar
Car: 05 CTS-V
Re: IMPORTANT QUESTION about storing my car for the winter.
I would start it once a week and let it run for a few minutes. Put stabilizer in the gas tank. I would leave the coolant in the car also.
Old Oct 27, 2011 | 11:17 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Do not start a stored car. That just fouls the oil up.
Use Sta-Bil. Make sure the tank is either nearly empty or nearly full.
Change the oil right before you store it.
Make sure the coolant system is fresh, full and bled.
Old Oct 27, 2011 | 11:19 PM
Aaron_SK's Avatar
Couple other things:
Throw a cheap cake pan or something on the passenger floorboard under the dash.
If the car will not be in a climate controlled area buy some of the dehumidifier chemical they sell for RV's and leave it inside. You would be shocked how much the glass sweats.
Old Oct 28, 2011 | 11:34 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
1st fill the gas tank(a low tank causes condensation)put some gas store in the tank Do a complete oil change,remove the battery and keep it on a workbench (preferably wooden do not keep it on a concrete floor)and keep the battery on a battery tender(storage mode),make sure your window washer fluid can handle freezing temp(if not drain it)cover with a dust cover and your good till spring.
Old Oct 28, 2011 | 08:35 PM
Pocket's Avatar
Car: 91 Trans Am
Actually for a car driven regularly through the summer months, just top off the tank and unhook the battery
If your battery goes dead after 2-3 months of sitting with no draw, its a dud anyways. You live up north so you'd better have antifreeze in your coolant and washer fluid that doesnt freeze (what kind does now a days?)
Gas has a shelf life of about 10 months so stabil is not needed. Most gas has a significant % of ethanol blended in so you need to fill the tank up to prevent the ethanol from drawing moisture
A small box of baking soda to draw some of the old car smell out isnt a bad idea
Old Oct 29, 2011 | 04:18 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
All good tips, but I would use Stabil. It's also good to pump your tires up over 40 PSI to help keep them round. They still might thump a wee bit for the first few miles in the spring, but they will smooth back out.
And definitely do not start a stored car in the winter. Leave it alone until spring.
Old Nov 1, 2011 | 08:57 PM
dharris89's Avatar
Car: 89 Firebird Formula 350
Engine: 350 tpi
It's also a good to cap your exhaust tips so critters won't get in. Shove some steel wool up there or use some plastic bags and rubber bands. Make sure you check air ducts and exhaust for nests or debris come spring Fried chipmunk stinks. Trust me.
Old Nov 1, 2011 | 10:57 PM
Pocket's Avatar
Car: 91 Trans Am
Critters up the exhaust... are you kidding?
Old Nov 1, 2011 | 10:58 PM
Aaron_SK's Avatar
I have known of it happening. It can create an exhaust fire if they build a nest up there.
Old Nov 5, 2011 | 11:21 AM
ewskater92's Avatar
Thanks for all the replies guys! I will be coming back home for thanksgiving and I'll make sure to get her all ready for storage.
What needs to be done after storage for the spring when you take it back out?
Old Nov 5, 2011 | 01:13 PM
Pocket's Avatar
Car: 91 Trans Am
Wash it and drive it
Old Nov 6, 2011 | 06:33 PM
ewskater92's Avatar
Ok, can't wait till spring!
MustangBeater20
Oct 29, 2022 09:20 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
