Security System/Computer issue!
Old Oct 29, 2011 | 04:33 PM
vichick rs's Avatar
Car: 1990 Camaro RS
Engine: 3.1L V6
I have a 1990 Camaro RS V6 3.1L. Since buying it, the security system would randomly turn on and I won't be able to crank my car for 2-30 minutes. Recently, it started occuring more often and for longer and longer periods of time. Then one day, the system locked and hasn't come off since. A mechanic put a different car's computer in, and the car started right up but idled real rough. But the security system came off.
What's going on here? I bought two replacement computers and still no luck. I know the Engine computers are pre-programmed, and may be read only, but how and what is making my security system lock on? And why is another car's computer able to let it crank?
Old Oct 30, 2011 | 02:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Security System/Computer issue!
bypass your vats. or burn a prom for your ecm with vats disabled i doubt its the ecms fault, sounds like you got lucky with putting the key in properly that one time, the pellets like to wear down and the barrel wont catch the proper resistance reading all the time.
Old Oct 30, 2011 | 02:57 PM
vichick rs's Avatar
Car: 1990 Camaro RS
Engine: 3.1L V6
BluFB I think ur absolutely right. Now when I took the PROM out, my fan comes on. The box was overheating with the PROM in, and when I took it out it seemed to maintain a normal temperature. Where can I buy a good VATS disabled prom? Of course regular auto supplies don't carry it....
Old Oct 30, 2011 | 04:48 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Find a local tuner or you can order from online, or get your own equipment and dive into the DIY prom world lol
Old Oct 30, 2011 | 07:32 PM
procharge87's Avatar
i have the same problem but no security light could that be the same problem
Bubbajones_ya
Jul 6, 2024 08:32 PM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
