engine vacuum issue
Old Nov 1, 2011 | 06:29 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
engine vacuum issue
I realized with the high flow exhaust system (edlebrock headers,3 inch tubing,high flow cat, and flowmaster muffler) there is no longer enough vacuum to open it i was wondering if there is a a way to boost up the vacuum enough to have the valve functioning again with out sacrificing anything in the exhaust or any major engine work
Old Nov 1, 2011 | 06:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: engine vacuum issue
what is it?
Old Nov 1, 2011 | 06:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Are you talking intake vacuum?
Old Nov 1, 2011 | 07:17 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
I'm going to go ahead and take a guess your talking about the EGR valve? What type of EGR valve do you have positive or negative?
Old Nov 1, 2011 | 07:20 PM
Engine: 5.0L 305
the egr valve runs off of the intake vacuum as well as the negative back pressure in the exhaust system however with this highflow exhausts system has reduced most of the negative back pressure so i need to find a new way to make up the lost back pressure vacuum to have the valve able to open during operation
Old Nov 1, 2011 | 07:23 PM
Engine: 5.0L 305
im going to assume that it is a negative valve as it runs off the back pressure of the exhausts but i could be wrong
Old Nov 1, 2011 | 07:30 PM
Engine: Lb9
Transmission: M20
http://www.agcoauto.com/content/plug..._articleid=207
Old Nov 1, 2011 | 08:05 PM
Actually I believe you have it backwards. A positive type EGR valve requires positive pressure in the exhaust system to allow the EGR valve to operate. When positive pressure is applied to the EGR valve it closes a vent inside the vacuum diaphragm so that engine vacuum can open the valve. With a high flow exhaust sometimes you can’t build up enough positive pressure to plug this vent so the EGR valve will essentially never work. Negative type EGR valves work in the opposite fashion (negative pressure) and don't seem to have this issue. Now without really knowing what type of EGR valve you actually have what drew you to the conclusion that this is the problem or that you even have a problem for that matter?
Old Nov 1, 2011 | 08:24 PM
Engine: 5.0L 305
i quess i could find the part number and try to find the opposite pressure than the one i have and hope it works
Old Nov 1, 2011 | 10:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What makes you think you have a problem?
Old Nov 2, 2011 | 10:28 AM
Engine: 5.0L 305
the valve not opening at all due to not enough back pressure and my ses light poping on when i hit 50mph but mine has an N stamped on it so im going to try a positive one to see if there is a difference
Old Nov 2, 2011 | 10:37 AM
Engine: Lb9
Transmission: M20
code 32? If you want the easy fix pm me
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
