Timing Question - Need QUICK reply!!!
Old Nov 2, 2011 | 10:09 AM
ndg1979's Avatar
Hi All,
A question for the techs here. Have an 90% original 1982 WS6 LG4 Trans Am with 105,000 miles. Of course, the Chevy 305 needs a pick-me-up with a new timing chain. I'm also going to have most of the other front end stuff changed out - water pump, fan clutch, alternator, thermostat, etc... by a shop this Monday.
My question is about the chain. Under the standard cover on the 305s, can you fit a double roller chain? I'd like to have a heavy duty chain in there. If the original cover won't fit a double, any recommendations on the strongest single chain? I only have a couple days to buy the part before the car heads to the shop.
The car is currently a daily driver, but will get a freshening up next year. I appreciate any and all suggestions. Thanks
Nathan
Old Nov 2, 2011 | 03:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No problem fitting a double roller under the stock timing cover.
http://www.summitracing.com/parts/SUM-G6600/
Old Nov 2, 2011 | 05:01 PM
ndg1979's Avatar
Re: Timing Question - Need QUICK reply!!!
Sounds awesome 5-7. Thanks. I'll be sure to pick one up.
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
