86 TPI Not Firing
Old Nov 7, 2011 | 04:17 PM
Pezster's Avatar
86 TPI Not Firing
I have a 86 TPI Setup , Painless wiring harness.
Fuel Pressure 42lbs.
Spark is good.
Symptoms
Car Started up for a few days , now doesn't stay running at idle.
Motor will fire some cylnders like it sounds like it wants to run.
Tryed spraying brake cleaner into plenum , engine went on fire.
Sparkplugs are wet.
Ideas
Sensor.
Spark is firing wrong time with piston position , leaving sparkplugs wet and cylnder full of fuel. (Sometimes backfire)
Possible Distributor is 180 out.
Old Nov 7, 2011 | 06:10 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: 86 TPI Not Firing
Make sure you have the correct firing order and wire position on the distributor. It's easy to install them one post off. Verify base timing as well.
Old Nov 8, 2011 | 04:17 PM
Pezster's Avatar
What will tell the ECU to kill the motor after few seconds of running.
Motor Runs for 2seconds then dies, Will start after letting sit for few minutes, otherwise just cranks over.
Old Nov 8, 2011 | 11:17 PM
Pezster's Avatar
Answer : Distributor. Erratic Spark.
The spark was weak, so i switched to another coil. Orange Spark , to Blue Spark.
The Spark was still Erratic but now strong, leaves ignition module.
http://auto.howstuffworks.com/ignition-system.htm
1992rs/ss
Jan 31, 2025 05:10 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
