electrical problem?
Old Nov 10, 2011 | 11:16 AM
1roc89z28's Avatar
electrical problem?
i have a 91 350 tpi camaro. runs good. but sometimes when i put it in drive , the car surges down, and feels like it wants to turn off. but it recovers quick and runs good after that. but when it surges down all the lights go down. they dim alot. my question is ,is this a electrical problem?
Old Nov 10, 2011 | 11:28 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: electrical problem?
sounds like it might be a idle air control issue. I would check you timing with the est disconected set that, then check your minumin idle speed adjustment.
Old Nov 10, 2011 | 01:19 PM
1roc89z28's Avatar
that is what i suspected. i took it out and cleaned it. but i never did minimum air adjustment. check my timing? u mean moving the rotor clock wise to get my timing up?
Old Nov 10, 2011 | 01:24 PM
Engine: Lb9
Transmission: M20
Yes, I was thinking the timing was retarded. Make sure you disconnect your timing plug with the engine off first. After that is tested or checked than pul the ecm into diagnostic mode and set the idle speed I believe its 450
Old Nov 10, 2011 | 01:37 PM
1roc89z28's Avatar
pull out my timing plug? were is it located? and how do i test it
Old Nov 10, 2011 | 01:41 PM
Engine: Lb9
Transmission: M20
you need to disconnect the timing est plug. Check you timing with a timing light on the number one cylinder.
http://www.carcraft.com/projectbuild.../photo_04.html
Old Nov 10, 2011 | 02:23 PM
1roc89z28's Avatar
oh ok thx for the pic. i know what your talking about now.is there anyway to do this whit out the timing light? im going to disconect the est cable. then turn on the car and move around the distributor. is that correct? after it sounds good just connect the est cable back?
Old Nov 10, 2011 | 02:27 PM
Engine: Lb9
Transmission: M20
yeh... I would use a timing light
Old Nov 10, 2011 | 02:35 PM
1roc89z28's Avatar
thank you. im going to try it and see how it goes. its going to be hard becouse at idle it already sounded good. but ill let you know how it goes. thx bro
Old Nov 10, 2011 | 02:41 PM
Engine: Lb9
Transmission: M20
if your doing it bye ear mark the intake and the distributor base with a permanent marker or nail polish so you can easly set it back if you need.
Old Nov 10, 2011 | 05:09 PM
1roc89z28's Avatar
well i did it already. i took the intake air box off. it sounded like it was sucking lot of air, when i had the distributor at a even idle. then i turned it off connected the est connection. and one thing ive noticed was that it starts right up. b4 this when it was hot it would crank for like 3 secs before it started. i dint drive it around to test it fully. but its starting right up. i wonder if i messed up back then when i took my intake manifold off (becouse of oil leak).
Old Nov 10, 2011 | 05:46 PM
Engine: Lb9
Transmission: M20
Bob's your uncle
Old Nov 10, 2011 | 05:51 PM
1roc89z28's Avatar
thx bro. replied so fast realy appriciate it.
Old Nov 10, 2011 | 05:56 PM
Engine: Lb9
Transmission: M20
np, ill send you the bill... jk
Old Nov 11, 2011 | 01:20 AM
1roc89z28's Avatar
runs good, but i lost all power. im going to recheck tommorow
Old Nov 11, 2011 | 01:22 AM
Engine: Lb9
Transmission: M20
maybe you should invest in that timing light
Old Nov 11, 2011 | 12:13 PM
1roc89z28's Avatar
yes seems like i have too. im looking at prices as we speak
Old Nov 11, 2011 | 07:25 PM
1roc89z28's Avatar
done got it back massive torque again. but it cranks alot b4 start. any relation between timing and starting?
toones
Jan 6, 2016 06:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
