First Start in 15 years. How to prepare?
Old Nov 12, 2011 | 06:25 PM
OSS's Avatar
OSS
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
Hey all, OSS here;
Picked up an '85 TA today (LG4, M5, 199,000KM's) for dirt cheap. Engine hasnt been run in 15 years. What precautions should I take before I attempt to fire her up? I was going to remove the plugs, squirt some ATF fluid in the cylinders, allow it to soak through the rings. Oil change, plugs, fresh fuel. Thinkin' about new V-Belts. What are other good ideas? coolant change too with due time.
-OSS
Old Nov 12, 2011 | 07:00 PM
Damon's Avatar
Re: First Start in 15 years. How to prepare?
That's a good start.
Get all the old gas out and replace with fresh. It's long since turned to sludge. A new fuel filter is a good idea too.
You want to get that junk out BEFORE you start pumping it through the lines and carb, clogging everything up.
Anything made of rubber is suspect. From fuel lines to v-belts to vacuum hoses.
And that includes the brake lines, too. If you get it fired up and running you want to be able to stop it again!! A car that won't run is a bummer but it won't kill you. One that runs but has no brakes is extremely dangerous.
Old Nov 12, 2011 | 07:02 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
cross your fingers
92camaroJoe
Jul 29, 2023 07:57 PM
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wylecoyote08
Nov 6, 2015 03:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
