1999 Firebird, 3.8 #6 cylinder misfire
Old Nov 21, 2011 | 10:26 AM
Guest
Guest
Posts: n/a
1999 pontiac Firebird 3.8 V6, 150k miles, seemed like one of the cyliders wasnt firing when you tried to accelerate, initially no check engine light came on, tested and got #6 cylinder misfire, had some corrosion on the wires so changed wires and plugs, changed the coil (tried more than one to make sure coil i changed wasnt bad), fuel injectors were also changed and electronics for FI check ok, no vacuum leaks, changed computer, checked cylinder compression (is 160 psi) after each thing was tested/changed car was checked and still had #6 cylinder misfire, one thing I noticed is some corrosion where the coil hooks up so possibly not getting a good ground.
I thought after checking all this that it might be an internal problem, possibly the CAM, but was told that if it was the CAM then I would not have gotten good compression on that cylinder.
Anyone know what might be the issue?
Thanks in advance for any help/ideas.
CG
Old Nov 21, 2011 | 10:36 AM
Guest
Guest
Posts: n/a
1999 Firebird, 3.8 V6 #6 cylinder misfire
CG
Old Nov 22, 2011 | 11:44 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 1999 Firebird, 3.8 #6 cylinder misfire
you would probably have better luck on the firebird v6 forum. this is a thirdgen site, and not that many people here have that engine
1992 Trans Am
May 10, 2023 07:19 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
db057
Aug 22, 2015 08:17 PM
Randomtask2
Aug 13, 2015 01:57 AM
cRoe4
Aug 7, 2015 08:46 PM
