after motor change - won't start
Old Nov 25, 2011 | 01:47 PM
biglano's Avatar
Car: 89 formula
Transmission: 5 speed
I changed engines in my 89 formula. 305 - 350. I had already removed the fuel injection and went to carburated. After the motor swap, the car doesn't want to start. turns over a few times, then clicking sound from starter area. I had the starter tested, battery tested. both check out ok. took out the plugs to see if it would turn over any better, didn't seem to.
any help would surely be appreciated.
Old Nov 26, 2011 | 02:13 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: after motor change - won't start
Poor battery cable connections.
Old Nov 26, 2011 | 11:33 PM
torque_is_good's Avatar
if it were the starter, then removing the plugs would have reduced the load and the engine would have cranked faster..Replace the battery
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
slade5612
Aug 11, 2015 07:19 PM
