Starter replacement
Old Nov 26, 2011 | 02:21 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Starter replacement
I'm going to replace the starter in my 87 IROC 5.7. I'm looking at a CVR 5323 mini. Problem is, I can't find any info on whether it needs a relay. My current ignition system is MSD box and distributor, the current starter is the factory original. I didn't install the MSD system so I don't know what if any modifications had to be made. On the Summit Racing site it says "No relay terminal for factory points ignition" for the CVR. Does that mean it doesn't come with one or doesn't need one? Any ideas, suggestions, things to look at, recommendations, etc?
Steve
Old Nov 26, 2011 | 07:35 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Starter replacement
No relay needed as points and condensers went the way of steam engines at GM in '75, IIRC.
Old Nov 27, 2011 | 04:47 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
yeah, no relay is needed. i went to a mini torque starter myself. noticed slightly faster starts, knocked a few lbs off. and best of all, not a pita to try to maneuver out, and back in like the stock ones! there great starters.
mhatfield 14
Oct 24, 2015 07:48 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
milk
Aug 10, 2015 06:26 PM
86Base
Aug 8, 2015 01:34 PM
