89 iroc shaking in drive, neutral, and chirp on acceleration
Car: 1989 Camro Iroc
Engine: 5.7 tpi
Axle/Gears: 2.77 BW
I was driving down the road at about 45 mph and I noticed the car was shaking and I was hearing a chirp sound from the engine area while hitting the gas. When I came to a red light I could really feel the car shaking and when I hit the gas I could hear this chirp sound coming from the front engine area. The sound continues while you accelerate
I pulled into a parking lot and popped the hood. You could see the the hood shaking while it was raised up. Car shakes while in neutral or park and also in drive. The chirp sound starts as soon as you hit the gas in drive.
The engine also isnt holding a steady idle but instead its SLIGHTLY up and down.
Again the shaking started as I was driving and does NOT go away when not moving.
Car seems to still have good power.
Any ideas please? maybe a motor mount? torque converter? flex plate? suspension breakage?
Engine: 4++,350 & 305 CIs
Re: 89 iroc shaking in drive, neutral, and chirp on acceleration
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Possible broken motor mount.
Car: 84 Trans Am
Engine: 305 for now
Transmission: 5spd
It may be a vacuum leak, if you have one, use a vacuum gauge, should be showing about 20 to 21 in-mg at idle, any lower then that shows a possible leak.
mustangman65_79
Aug 11, 2015 03:17 PM
