hard start no power when increasing throttle
Old Dec 2, 2011 | 01:30 PM
markmutko's Avatar
my car has a problem that i have been trying to trace. i replaced pretty much everything but still no solution. It needs carb spray to start and when she is running she runs really rough and when i try to accelerate it bogs down. I replaced the plugs, wires distributor fuel filter, timed it and the ignition ecu. Can a computer be bad on this car?
Old Dec 2, 2011 | 08:08 PM
ex-x-fire's Avatar
Re: hard start no power when increasing throttle
We need to know what you got there, carb, tbi, tpi, ect.
Check engine light flashing?
Old Dec 2, 2011 | 11:36 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
To me it just sounds like a fuel deficiancy.
When you say carb spray, do you make carb cleaner or starting fluid? Im assuming starting fluid, because carb cleaner would make it bog down more lol.
It would help to know if were talking carb, tpi, or tbi tho..
If its carbed, try this: pour some gas down the carb thru a gas tank, cup, ect.. Then try to start it.
Be careful not too put too much in, because then you will flood it. If it starts up, great! Now you know your problem, its not getting enough fuel. If little or no improvement, we'll try some other tests. But to me it def sounds fuel related.
Old Dec 3, 2011 | 05:25 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
what did you set the inital timing at, and how did you set it?
Old Dec 3, 2011 | 06:49 PM
markmutko's Avatar
Its a 5.7 tpi. Yes i was starting fluid lol. I just marked the distributor cap on where it originally set then it put in and matched the lines up.
Old Dec 3, 2011 | 06:51 PM
markmutko's Avatar
the was running perfect and this happened while i wss driving. Could a vacuum line cause this much problems
Old Dec 3, 2011 | 06:53 PM
markmutko's Avatar
Should i take it to a shop and hook it up to a diagnostic check?
Old Dec 3, 2011 | 07:02 PM
travis401's Avatar
Car: 91 Camaro RS
get a timing light from the local auto parts store and verify timing. and yes a vacuum leak can cause it to run rough as well.
Old Dec 3, 2011 | 07:29 PM
ex-x-fire's Avatar
OK tpi, check the fuel pressure, make sure it holds pressure after the engine is off.
Old Dec 12, 2011 | 08:18 AM
markmutko's Avatar
Ok i replaced the fuel pump fuel filter and sending unit. It is not holding pressure i dont know if its coming from locking cap or the fuel tank is leaking. how do i test this? can i use gasket sealer to somehow fix this?
Old Dec 12, 2011 | 12:40 PM
ex-x-fire's Avatar
Pull the vacuum hose on the pressure regulator, if its bad, fuel will leak out there. Prime the engine first. You could also have injectors leaking down.
Whats the pressure while running?
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
perZ
Aug 15, 2015 01:17 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
