Which roller rockers?
Old Dec 6, 2011 | 12:03 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I'm working with a guy to get my engine built, at my request we are working close together so that I can learn a little bit more about engine & engine building as we go.
I know what I need in terms of rockers and that I want full roller; in looking at Summit Racing, there appears to be 5-6 different sets with a difference in price of around $200, all for basically the same thing (full roller, 1.5 ratio, aluminum, 7/16 stud mount). Just wondering if there is really that much difference in the brands or if any are better or worse than others. Thanks.
Old Dec 6, 2011 | 12:16 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Which roller rockers?
Personally I stay away from the china brands not because they are not USA but because I have heard a lot of mixed reviews.
A lot of guys seem to like these for budget builds
http://www.compperformancegroupstore...AlumRockerArms
Old Dec 6, 2011 | 10:54 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Stay away from anything Proform. They are poor quality chinese junk. Crane Golds are nice, (have them on my car) The Comp Cams rollers are also very nice and so is Harland sharps.
Old Dec 6, 2011 | 11:14 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I got a deal on Comp Pro magnum rockers $295, from what I have read they are very good rocker arms. I also read a lot of good things about scorpion rocker arms and Harland Shaps, however I went with the pro magnums because I personally did not want aluminum. My cousin has had the Crane Gold rockers for several years on his show truck with a BBC 468 and had no problems.
Old Dec 6, 2011 | 11:20 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Crane Golds are fantastic and can be found used pretty easily.
Old Dec 7, 2011 | 01:36 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Scorpions are made in the USA. I found mine the cheapest at ... Amazon!
Old Dec 7, 2011 | 06:15 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Thanks for all the replies. I will look later and see where I can find the best deal on the brands mentioned and go with one of them.
Thanks again.
Old Dec 7, 2011 | 06:25 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I prefer Comp pro magnums or the newer ultra pro magnums.
I also really like Scorpions.
Old Dec 7, 2011 | 06:27 AM
midias's Avatar
I have these they work great but are expensive.
http://www.compperformancegroupstore...AluminumRoller
Old Dec 7, 2011 | 03:38 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
+1
Not a fan of aluminum in rocker arms. They will fatigue over time. The Comp rocker arm bodies are steel and they use larger trunions that wont wear out as quickly AND they are rebuildable.
Old Dec 7, 2011 | 04:15 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Depending on what year your car is. You may need the self-aligning style rockers.
Old Jan 1, 2012 | 12:28 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Happy New Year!
I have a couple of more questions. My engine builder ended up getting heads that (1) have 3/8" studs instead of 7/16" and (2) has perimeter bolt valve covers. The heads also have guide plates, but my builder said he can take them off if I want to use self-aligning rockers (which in his view, are better).
So...I'm having a hard time finding the proper rockers. I found some Scorpion ones that I like, but they are narrow body for center-bolt valve covers (according to the description). At this point, I'm leaning towards going with non-self aligning since I can find exactly what I want. Thoughts?
Old Jan 1, 2012 | 12:39 PM
midias's Avatar
http://www.summitracing.com/search/M...s/?Ns=Rank|Asc
Narrow body is not an issue even if you use perimeter bolt covers.
Old Jan 1, 2012 | 12:55 PM
elesone's Avatar
Here's a good reason why I support N/A made products. Not that they do not have quality issues, but this confirms my feeling. I did a rebuild on a 350 and one of my rituals is to verify oil is traveling where it's suppose to. I do this while the engine is on the test stand and crank it over with no spark plugs. The attached pic shows that one rocker was NOT lubricating the the bearing. I wonder why. So do not assume new is good. Check everything. I like the COMP products, never had issues and the support was always there when I needed it.
Old Jan 1, 2012 | 03:50 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
So I can get the narrow body ones no matter what valve covers I'm using? If so, I plan on going with the Scorpions. Thanks.
Old Jan 2, 2012 | 12:31 AM
watajob's Avatar
Car: 92 T/A 'vert
Yes. Narrow bodies can be used with perimeter or center bolt. They are mandatory with perimeter bolt. Self aligning rockers and guide plates are mutually exclusive due to push rod binding issues. Be sure your builder puts washers under the rocker studs that are the same thickness as guide plates to retain proper geometry.
Old Jan 2, 2012 | 06:21 AM
midias's Avatar
Yea go narrow self aligning and if you ever decide to go vortec heads you wont have to change anything.
Old Jan 2, 2012 | 08:41 AM
3rdgenmaro's Avatar
Car: 88 IROC
Originally Posted by watajob
Yes. Narrow bodies can be used with perimeter or center bolt. They are mandatory with perimeter bolt. .
I thought they were mandatory on centerbolt? Atleast Im running Scorpion narrowbody SA rockers under my stock vortec valve covers.
Old Jan 2, 2012 | 10:20 AM
midias's Avatar
You are correct the narrow bodies are requires for most center bolts.
Old Jan 2, 2012 | 06:46 PM
watajob's Avatar
Car: 92 T/A 'vert
Correct. I eff'ed up. My bad.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
