lose of oil pressure
Old Dec 6, 2011 | 08:04 PM
Stryker1028's Avatar
when i am going down the road running 55 to 70 mph oil pressure is fine but when i stop at stop sign or red light oil pressure drops to 0 and car stalls out.what do i do. what is wrong. how do i fix.by the way its a 91 camaro rs with a 191 6 cyl in it.
Old Dec 10, 2011 | 02:56 PM
Re: lose of oil pressure
ok changed the oil pressure switch then tried to crank.it cranked oil pressure was fine again then i changed the oil and oil filter now it wont crank at all plz help me with this
Old Dec 11, 2011 | 07:29 AM
grumpyvette's Avatar
where are you located?
Old Dec 11, 2011 | 07:56 AM
athens georgia
Old Dec 11, 2011 | 08:30 AM
ex-x-fire's Avatar
The oil light came on because of low idle or stalling issue.
Now the starting problem, does the starter turn over the engine?
Security light on? Check the battery connections, ground to the block, 12 v. at large starter wire (all the time), 12v. at small wire at starter when cranking.
Old Dec 11, 2011 | 08:31 AM
Im in loxahatchee fla. if you were local Id have suggested I could look it over,or maybe one of the guys on the site located in your area, could help you out, you first need to verify the oil level on the dipstick, and get the starter to spin the engine and determine your getting fuel pressure, oil pressure and spark at the plugs
Old Dec 11, 2011 | 02:15 PM
ok have oil pressure have fuel (fuel pump is working hit button on fuel line got sprayed in the face with gas)so getting gas checked fire have fire every where including fire to distr. but no fire to plugs. took dist. cap off distrib.is full of rust (car set up for 1 year) drove it for awhile now wont crank thinking maybe the dist. went out.maybe im right i dont know gonna try to get a dist. to see if it works.any other suggestions r welcome
Old Dec 11, 2011 | 02:16 PM
by the way motor will turn over just wont fire
Old Dec 11, 2011 | 03:19 PM
ex-x-fire's Avatar
A hole in the rotor?
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
