help replacing starter
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
I am having issues taking out the bolts that attach the y pipe to the manifold is it possible for me to just take off the clamp on the other end of the y pipe to give me enough room to take out the starter?
Re: help replacing starter
You shouldn't need to touch the exhaust to remove the starter, at least not if it's the factory exhaust.
Turn the starter with the nose down. Comes RIGHT OUT.
Car: 1986 IROC-Z28
Transmission: Boring Automatic
Is there any difference if you have headers installed? I have been putting this project off for a few months due to being afriad it's a PITA. I believe that they are Edelbrock.
Car: '84 Berlinetta, '86 Z28
Engine: 2bbc 2.8, MPTI 5.0
Transmission: 5spd manual, 4 spd auto
I am having similar issues but I have aftermarket dual pipes. would I have to remove the shroud to pull it out. Because I have one pipe and two cooling lines and I don't want to stress the lines. If there's a trick let me know PLEASE
mhatfield 14
Oct 24, 2015 07:48 AM
db057
Aug 11, 2015 10:11 PM
