wont crank
Old Dec 10, 2011 | 03:51 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
wont crank
I have a 89 camaro with a 2.8 and won't crank it has power battery is new and alternator is new all lights come on. I took the starter to autozone they said the starter was good what else could it be?
Old Dec 10, 2011 | 04:32 PM
ex-x-fire's Avatar
Re: wont crank
Does the ignition key have a chip? Might be a VATS issue.
Check for...
12v all the time at big wire on the starter.
12v at the small wire on the start only when cranking.
Make sure the starter has a good ground to the block.
Old Dec 10, 2011 | 04:55 PM
NCGuy68's Avatar
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
Re: wont crank
Did you actually see and hear the starter work at Autozone? Some of those guys are flacky.
Old Dec 11, 2011 | 06:54 AM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Re: wont crank
I heard a buzzing sound like they hooked it up to streight power like a electric motor lol but I guess that's what it is. I'm going to try to check out the wiring today as for a security system I know that the 89s are supposed to have it but my car has been a repo a few time in its life and some where down the road they changed the key and it doesn't have the chip
Old Dec 11, 2011 | 11:09 AM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Re: wont crank
This is what I found when I took off the starter
Old Dec 11, 2011 | 12:48 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: wont crank
that looks like some awesomely bad wiring.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
