Is it my starter?
Old Dec 11, 2011 | 09:01 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Is it my starter?
Ok here's the deal. I think my starter may be going bad. I tested it at work and here are the results.
Beginning Volts 12.55
Ending Volts 9.96
Est. Draw 340 amps
From this it seems I need to replace my starter. Could anyone tell me if these readings are anywhere near spec or if I'm right and need to replace my starter. Thanks
Old Dec 11, 2011 | 09:24 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Is it my starter?
It seems borderline, but it may not be the problem. You might want to check cabling resistance, terminals ...etc. if you don't find anything that doesn't meet specs then replace the starter.
Old Dec 12, 2011 | 06:14 PM
Sheppard's Avatar
Car: 84 Trans Am
Engine: 305 for now
Transmission: 5spd
Have you recently done any major engine work with your car? An engine problem can sometime cause an extra current draw while trying to start.
Old Dec 12, 2011 | 10:00 PM
macmatt's Avatar
Engine: 305 TBI
No. Nothing that would effect it like this. I do know that it has a Duralast battery from autozone, and having worked there I know how prone the newer duralast batteries are to this kind of issue. The battery keeps testing good and so does the alternator so I just figured I'd look a little further into the starter.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
