Car makes loud noise above 3700
Old Dec 14, 2011 | 04:50 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Starts up fine and idles well. its an 84 trans am with a 350 and t5. Its not a rod knock or an arcing wire and it makes this loud banging popping noise above 3700. It sounds horrrrible could be the coil cap and rotors? Or something else? Help!!!!
Old Dec 14, 2011 | 06:15 PM
seibertjd's Avatar
Car: 1984 Camaro Z28
Engine: SBC 350
Transmission: B-W T5
Re: Car makes loud noise above 3700
How is your acceleration? Does it sound like a backfire? Have you checked your timing advance? Where is the sound coming from, can you tell? Is it only when driving or does it happen when the car is standing still? Does it happen while you are giving it gas, or after you let off?
Old Dec 14, 2011 | 07:10 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Its while giving gas both in neutral and driving. Its only on medium to hard acceleration and it isnt a backfire. It sounds like a miss almost. I check the timing right at 7 degrees the advanced is good as well. It sounds like its coming from the passenger side of the motor almost out of the carb its hard to tell. all 4 cylinders on that bank are running around the same temp as well.
Old Dec 15, 2011 | 04:14 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Im thinking it might be a cam. I pulled the valve covers off and the one intake lifter on cylinder 4 is moving slow >:O Ill post a video of how it sounds. i checked the push rods and they arent bent
Old Dec 15, 2011 | 04:24 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
http://www.youtube.com/watch?v=baHxG...e_gdata_player
Old Dec 15, 2011 | 04:27 PM
seibertjd's Avatar
Engine: SBC 350
This one might be a little out of my league... I am still learning when it comes to this stuff. Did you check or readjust your valve lash? Is it possible that you have a lifter that is sticking at high RPMs? Just throwing stuff out there at this point.
Old Dec 15, 2011 | 04:31 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
I adjusted all the valves both intake and exhaust. =( Looks like the manifold is coming off tomorrow.
Old Dec 15, 2011 | 05:36 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Just got thinking, could it be the module?
Old Dec 15, 2011 | 11:44 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
kind of hard to tell from the vid, but i believe you have a problem with an exhaust valve not opening properly.
if an exhaust valve doesn't open all the way, the motor will pop back thru the intake. the less the exhaust valve opens, the worse the pop is.
if an exhaust valve isn't opening at all, then you can get the pop at idle.
a rounded lobe on the camshaft is what normally causes it.
flat tappet lifters without the right additives in the oil, mainly ZDDP (which many oils are now missing), and the cam and lifters start eating each other.
from the vid, it sounds like yours is just starting to go away.
if your cam is going away, the only fix is a new cam and lifters.
some people have gotten away with just replacing the cam and lifters, but because the motor will have metal from the lifters and cam in it, i strongly recommend rebuilding or replacing the motor, and preferably going back with a roller cam.
Old Dec 16, 2011 | 01:10 AM
guitarguy92b's Avatar
Car: 87 ws6 trans am
Engine: 305sbc
glad i found this, im having the same problem with my 92 but its worse, alot worse, it sounds like a back fire and kinda feels like its flooding out, im thinking IAC could be causing some of the problem, and im currently getting around 10-12mpg with a bone stock 305 which is completely ridiculous hopefully both of us can get some answers and help here
ill try and get a video on here of what mine is doing and post it tomorrow, maybe we both have the same problem
Old Dec 16, 2011 | 06:30 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Well I changed the module today and still popping. The only reason I don't think it's the cam is because it idles like a dream and uP to 3000 rpm is fine. Could this still mean that it's a cam? And I was also getting horrible mileage
Old Dec 22, 2011 | 02:11 AM
DENN_SHAH's Avatar
you said that the intake rocker on cylinder 4 is moving slow, i would almost bet its actually the exhaust rocker.
even though it runs fine at idle or low throttle/ RPM, it can still have one or more lobes going away on the cam.
the more throttle you give it, the more air the motor draws in.
the lobe can still be good enough to open the exhaust valve enough so it doesn't build pressure in the cylinder until you start giving it more throttle.
Old Dec 22, 2011 | 06:12 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That sounds like a worn cam lobe.
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
